Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Nav screen shutdown
Old Mar 9, 2020 | 11:29 AM
smurtaza's Avatar
7th Gear
Default Nav screen shutdown
I have a new to me 05 FFRR that I just got done fitting a used engine in. Runs good but the Nav was stuck at Logo with light blinking. I have bypassed the phone module and radio/nav runs but only for 30 seconds and then shuts down. So the phone module is bad for sure but why would the unit shutdown after exactly 30 seconds.
Restart the car and again it runs for exactly 30 seconds and completely shuts down. Only restarting the car wakes it up. I see no audio related faults on IIDTool.
Any ideas? Any help will be greatly appreciated as I'm completely out of ideas on what to try next.
Old Mar 10, 2020 | 09:04 AM
smurtaza's Avatar
7th Gear
I have tried electronics reboot by disconnecting the battery and shorting negative/positive terminals, but same issue. I do have a fault on IIDTool now related to audio: U1A03-62 (2B) Vehicle configuration parameter - Algorithm based failure - signal compare failure
I'm going to try to play with configuration and see if that helps. Any ideas on what the above fault means?
Obrien.james
Freelander
Feb 12, 2020 05:11 AM
timbrehse
Sep 4, 2019 12:04 PM
jaimeeduardo1968
Dec 5, 2010 07:08 AM
ashmarie73
Nov 27, 2010 12:46 PM
bigswilson
Apr 29, 2008 06:02 AM
