Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
No speedometer/ ABS HDC Need help
Old Oct 28, 2020 | 07:49 PM
ninjaff21's Avatar
Default No speedometer/ ABS HDC Need help
Having trouble figuring this one out! Bought a cheap AS-IS rangie with the issues in the title! Have codes for both front wheel speed sensors along with speed sensor A. Replaced both front sensors and codes instantly came back after a quick drive and the speedometer still didn’t work. Truck is coil spring swapped and has tons of EAS codes. Not sure if that will have an affect. All the wires seem good and my connections were good on the ABS sensors. Using an Autel reader and those are the only codes the car has. Any input on what to check next is appreciated because i am stumped! Anything I should even double check!
Fatkid81
May 23, 2015 07:05 AM
Tony C
Nov 14, 2014 01:25 PM
discosoldier
Feb 23, 2011 11:20 PM
kman3786
May 4, 2009 02:44 PM
