Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Oil Pump Fail Engine Cut Off Sensor
Old Feb 7, 2019 | 08:25 PM
Seedyrom's Avatar
Default Oil Pump Fail Engine Cut Off Sensor
I'm considering the purchase of a 2003 Range Rover with the front oil pump failure. The owners says it will run a few seconds then it cuts off automatically? Price is $1200 with 167k miles if you're curous.
Is there a cut off sensor when no or extreme low oil pressure occurs? If so does it reset automatically after the problem is fixed or is there a reset procedure? The suv sat for about a year before the owner
gave up, he said the dealership quoted $1400 estimate to fix. Far cheaper DYI plus the parts aren't as high when I search. I searched this forum a little but didn't find much. This is a new issue since
I'm used to older rovers. I owned a 97 discovery II for 7 years, loved it even more after fixing the battery drains, well most of them.
RossN99
Jul 10, 2019 06:19 PM
wardo
Mar 8, 2010 03:08 PM
andy
Jan 15, 2009 02:25 PM
trioinfo
May 24, 2008 08:34 AM
doc1976
Apr 29, 2008 05:17 PM
