Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
5.0L Supercharged head gasket replacement
Old Feb 7, 2019 | 09:54 PM
Kieffs's Avatar
4th Gear
Default 5.0L Supercharged head gasket replacement
I have a 2010 L322 Supercharged with bad head gaskets. I have been unable to locate specific instructions on how to strip the top half of the engine. I am hoping that someone has actually replaced the gaskets and can provide factual insights and advice. Thanks!
Old Feb 8, 2019 | 06:27 AM
I am no help but good luck and post up your progress so others can learn as well.
Old Feb 11, 2019 | 09:48 AM
User's Avatar
Simple job. You'll need the special tool for removing injectors. Go step by step and remove the intake tubing, supercharger, valve covers, injectors, and then remove the exhaust manifold from under the car, not from the head.
Chances are if it needs a head gasket from overheating, the engine is done. Check block deck warpage.
Gnomadf
LR4
Dec 21, 2018 02:23 PM
pinkytoe69
Apr 20, 2013 07:22 PM
dave41
Aug 2, 2010 04:42 PM
Robwsup
Mar 11, 2010 10:28 PM
Gordon Bombay
Dec 15, 2009 11:03 PM
