Looking at a 4.4 LR3 with a possible blown oil pump
Old Jul 10, 2019 | 01:32 PM
RossN99's Avatar
Default Looking at a 4.4 LR3 with a possible blown oil pump
So I spotted an 05 LR3 SE 4.4 with 186,000 miles that the owner mentioned had a possibly bad oil pump. I know that oil pump failures are rare on the 4.4 and so I was wondering what else could possibly be causing low oil pressure. We currently have an 07 RR full-size with a 4.4 and a few 4.6 discoveries that I’ve rebuilt so I wondering The difficulty level of getting to the oil pump on the 4.4 if that were to be the problem. Thanks.
Old Jul 10, 2019 | 02:01 PM
abran's Avatar
I would walkaway unless you are buying at scrap price. I have never repaired one but have broken down those motors, not simple. Plus, whatever damage has been done with the low oil pressure? 4.4 motors are cheap because they rarely fail, swap in a used and walk away a winner.
Old Jul 10, 2019 | 05:07 PM
RossN99's Avatar
Yeah I guess I didn't mention that I've pulled motors before and wouldn't be opposed to replacing it being that you can find 4.4's pretty cheap all day, I was really just curious about oil pump location and if anyone on here had messed with them before. Price is still a little high right now for the situation but the seller sounds negotiable.
Old Jul 10, 2019 | 05:28 PM
DakotaTravler's Avatar
I agree with abran, low oil pressure usually means damage if its it running. I would look at he cost of a replacement engine and book time for labor - deduct those from the asking price. Even if you are doing the work yourself.
Old Jul 10, 2019 | 05:51 PM
RossN99's Avatar
Believe me I’m familiar with low oil pressure as I’ve owned two 2003 Land Rover Discoveries and have purchased one with a failed oil pump. Yes, I know this is a much more complicated engine. I understand buying a vehicle and negotiating the price according to the work required whether it’s done at a shop or not.
Old Jul 10, 2019 | 06:19 PM
abran's Avatar
its in the general same location as on the D2 motor, behind front cover. I think both chains are wrapped around it.
velija
Mar 11, 2014 01:59 PM
rewi9d
Apr 12, 2012 06:12 PM
lrlover
Mar 16, 2010 03:43 PM
Rover Curious
Aug 20, 2009 01:33 AM
shagybruce
Feb 20, 2007 07:11 PM
