Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Reverse polarity attempted jump start. Now what?
Old Jun 3, 2019 | 11:11 PM
GLB123's Avatar
3rd Gear
Default Reverse polarity attempted jump start. Now what?
2009 No. American L322 won’t start after reverse polarity jumpstart attempt. All electrical seem to work fine in key position 1 but nothing happens when key is turned to position 2. No noise from starter. Nothing. But I do not believe it to be a starter problem. Looking for troubleshooting guidance on CJB or other electrical troubleshooting. Will check tomorrow to determine if voltage is getting to starter. I suspect it isn’t.
What relays, fuses etc might be at fault? Or is the CJB fried? Or EJB? Help!
Any guidance will be deeply appreciated.
Old Jun 24, 2019 | 08:10 PM
GLB123's Avatar
3rd Gear
Default The No-Start riddle solved!
The “No Start” riddle solved. After spending countless hours googling and pulling fuses and swapping relays I finally found the problem and it had nothing to do with a reversed polarity jumpstart.
I stumbled upon upon a post discussing the gear selector causing a non start situation like mine so
in frustrated desperation I thought I would give it one more try. Although I had tried to start the beast in Park and in Neutral before with no results, I recalled that the gear selector cable had recently been adjusted because the car was popping out of drive from time to time. So this time I shifted the selector firmly through the gears and still no start in Park, but if I put it in Neutral and pushed forward slightly while turning the key VOILA it started! And sure enough, I have to manually hold the selector in Drive for the transmission to engage. Looks like I’ll be replacing that cable.
Old Jun 26, 2019 | 12:06 AM
FlyingZebra34's Avatar
Glad you figured that out. Was scratching my head there bud.
Jaswinger
Aug 4, 2016 05:18 PM
Nov15
Oct 31, 2013 08:57 AM
raim212
Nov 16, 2012 09:27 PM
bandkbyers
Jan 6, 2010 06:20 AM
sleeping dog
May 2, 2007 02:58 PM
