Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Terrain Response & Suspension issues
Old 11-19-2018, 11:41 AM
VIPER66's Avatar
3rd Gear
Default Terrain Response & Suspension issues
I have a 2008 LR RR HSE w/120K miles.My front end is lower than usual and will not raise up. It bouncy when I hit small bumps.When I start it up, the Terrain Response is in normal mode (Special Programs Off), On-Road Indicator is lit, and the High Range is lit. After about 30 seconds the Terrain normal & On-Road indicator lights go out, but the High Range light stays lit. When this occurs I can’t make any changes to the Terrain Response. I have no clue as to why it is doing this. Help!!
Sequence of events1) 1st Start2) After 1st Start #13) 3 Minutes after Idle4) After 2nd Start #15) After 2nd Start #2
1st Start
After 1st Start
After a 3-minute Idle
After 2nd Start #1
After 2nd Start #2
Old 11-19-2018, 02:54 PM
Received 1,481 Likes on 1,209 Posts
Looks like you have an EAS fault and it is shutting down systems as a limp limp effort.
If it is isolated to the front. It could be an airline, valve block height sensor or spring.
To better diagnos the issue a Land Rover specific tool to pull codes is needed
Old 11-20-2018, 11:17 AM
VIPER66's Avatar
3rd Gear
Thanks Dude!
I really appreciate the quick reply.
The Deputy
12-09-2017 01:08 PM
loanrangie
05-17-2016 04:36 AM
dipdgarage
01-15-2014 07:19 PM
aTX427
03-03-2010 08:59 AM
GMachineFAB
12-29-2006 01:57 PM
Quick Reply: Terrain Response & Suspension issues
