Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Blown 5.0 Supercharged Engine
Old Nov 30, 2021 | 10:56 AM
Bradley G Goodbread's Avatar
6th Gear
Default Blown 5.0 Supercharged Engine
I have a 2014 Full Size Range Rover with Supercharged 5.0 Engine with 134,000 miles on the clock. I purchased it 2 years ago for $30,000 with 101,000 on the clock. Two months ago I was driving on I95 and all of the sudden the truck lurched like I ran over something and the engine just died and I coasted to the side of the Road. I had it towed and the Mechanic Shop says that the Engine is Blown. No Compression. The truck ran hot because I could hear and smell it when I pulled to the shoulder, but the Temp gauge NEVER moved off of Normal. I was told that this is a common problem in these Vehicles. I am looking for anyone that had this happen. I got a price of $12,000 for a Reman Engine from California, then about $5,000 for the Install. I was offered $9,000 from the Range Rover Parts place in Tampa. So, Repower at a cost of approx $18,000, sell it for parts, or take my time and try to find a used engine. Thoughts?????
Old Dec 5, 2021 | 04:23 PM
Groucho123's Avatar
Well...judging by your pictures your in love with it.
Get the new engine and enjoy it I say.
Old Jan 25, 2022 | 01:18 PM
docharo78602's Avatar
Kind of same thing happened to me here in tx. I have a 2015 Range Rover supercharged and it began leaking antifreeze. i took it to Austin Rover works. It needed a new water pump, after the installation and the master mechanic test drove it he said it didn't feel right. They did a block test on the motor and i was told it changed color almost instantly indicating a "Superbad blown head gasket". I was told around 10 for the job, heads would almost defiantly need machining and new timing chain while they were at it. also wouldn't know if or how bad block was warped until they take off heads. was suggested i just get another motor. I was also told it would be 2k to take off heads just to check the block if i wanted to check the block first to see if would just do heads ,gaskets and chain or just swap another motor. i found Sharper Edge Engines LLC. out of Florida with a lot of upgrades to the motor. anyone heard of them?Sharper Edge Engines LLC offers,
A New Re-Manufactured engine with one-year- unlimited Mileage warranty, shipped in will be: Unpainted 11,500.00 with all the additional upgrades. With heat treated metal sleeves on the bottom end (see below).
Upgrades: Completely resealed, new upgraded timing actuated to fit an 8 MM Chain. upgraded new 8 MM Chain and 8 MM Tensioners. upgraded timing chain guide & rails to Aluminum/plastic and a 3-layer head gasket, new bearings, new ring, new connecting Rods, new crankshaft, new Pistons, New Oil Pan, New Valve covers, Remanufactured Heads, New Engine Oil Cooler, New Spark Plugs.
We ship it in a Reinforced Crate.
A set of Remanufactured injectors will be 500.00
Old Core is due.
We also can send this package with the engine for 850.00:
Water Pump
Thermostat
Heater Pipe
Hose from Heater Pipe to Throttle body
2 Hoses from water pump to Throttle Body.
2 Piece water Outlet pipe next to supercharger
water outlet pipe with extra o-ring from oil cooler to water pump
2 Piece gasket between engine and supercharger
Typically, when one is looking for a used Land Rover or Jaguar engine, they are speaking to people who source used engines from salvage yards. it is not what we do. We are the only Company in the US that does these upgrades.
Old Feb 8, 2022 | 12:18 AM
6th Gear
Old Core is due.
Water Pump
Thermostat
Heater Pipe
That is the same outfit that I priced a replacement engine from. My Rover has over 130,000 miles so I have opted to sell it to Rover Parts in Tampa, FL. They offered me $9,000 with the blown engine, so I am going to do that and put the $9,000 towards the New 2014 Autobiography with 61,000 miles that I bought today for $57,000.
LRScott
Jul 19, 2021 09:11 AM
twaszak
Aug 4, 2020 03:40 PM
1999rover
Nov 3, 2013 01:51 AM
Dodger
Jan 2, 2011 01:05 PM
