Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Charging
Old Jan 8, 2025 | 09:01 AM
Rambler's Avatar
Default Charging
Hi Guys
l have a problem with my L405 Vogue it started after changing both batteries now get 2 warnings on dash low battery please start engine and charging system fault when these come up some systems don't work eg tailgate operation, stop start.heated seats,steering wheel l have a topdon dongle that l used to tell battery replaced friend also tried launch scanner. Faults still persist although intermittent l took reading of battery when showing charge sys fault engine running 14.00 volts any help would be much appreciated
Rambler
Old Jan 8, 2025 | 10:55 AM
wcc18999's Avatar
How old is your current battery? Some ageing batteries will not hold charge for long after you charge them. If your current battery is older than 4 years, get a new one.
Old Jan 8, 2025 | 11:10 AM
Rambler's Avatar
Hi
Both batteries new 8 mths ago
Rambler
Old Jan 9, 2025 | 04:53 AM
wcc18999's Avatar
If you bought the batteries from your dealer 8 months ago, they should still be under warranty. If you bought them elsewhere, they should also have a warranty. Take them back and let them replace the batteries. If replacing the batteries does not cure your problem, you have an electric drain that will need to be diagnosed. Do you have anything aftermarket installed on your vehicle? Have you checked the ground on your car?
T45HAM
LR4
Oct 20, 2023 10:45 AM
WALLACEJ
Mar 30, 2021 05:01 PM
hshamamian
LR4
Jan 20, 2020 03:30 PM
Jtm123
Mar 20, 2017 10:17 AM
ceven18
Feb 28, 2008 09:55 PM
