Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
L405 Stuck in Park
Old Apr 8, 2021 | 06:38 PM
findre's Avatar
4wd High
Default L405 Stuck in Park
Sorry if this is posted elsewhere. 2016.5 HSE Diesel. Selector comes up, but will not turn when brake is applied. I do not hear any click, like one that would release the ****, and I cant recall if it ever did that.
I tried parking brake, on off, restarted a few times, and I do have a CEL because I swapped my brake pads and had a wear sensor that I have not replaced yet, but that has been going on for a few months without issue.
Drive car a short distance a few times this morning and now its stuck.......I also typically shut car off without putting in Park, so maybe my fault for doing that. Any suggestions please.
Old Apr 11, 2021 | 09:54 AM
Groucho123's Avatar
Try and disconnect the battery and wait 10 min or so. The system should reset. Worth a try!
Old Apr 13, 2021 | 11:56 AM
findre's Avatar
4wd High
Did battery disco 10 mins, touched pos and neg for a few seconds.. Did the hold paddle for 20 seconds. Still stuck in Park
Old Apr 19, 2021 | 10:42 AM
findre's Avatar
4wd High
I replaced the Transmission Control Switch (TCS), Fixed the problem. For whatever it's worth, here is what the inside looks like. I have not tested the solenoid, but I suspect there is a failure in either the windings, or the board itself. I will test further, but as you can see from the locking pin, it can be bypassed to allow the shifter to turn, in case anyone wants to just do that.
Old Apr 19, 2021 | 10:44 AM
findre's Avatar
4wd High
Also, it does click when you press the brake, so no click, locked in park.
Old May 25, 2021 | 02:07 AM
Disco Sport's Avatar
my 2015 discovery sport, selector stuck in P, phoned recovery firm, they asked me to start engine, and pump the foot break, it worked all gear selections available!!’
Old Dec 28, 2021 | 11:42 AM
Mike RRSC's Avatar
Where did you find the transmission control switch? How much was it? How easy was it to replace?
Old Apr 29, 2023 | 11:43 PM
k9gears's Avatar
FOUND a technical bulletin
https://www.tsbsearch.com/Land-Rover/LTB00455NAS1
Old Apr 30, 2023 | 10:15 AM
findre's Avatar
4wd High
I don't think the TSB will help. The solenoid is usually dead. I saved my old shifter to see if I can either create a work around for emergency rotation, or replace the motor in shifter to make it work again. $350 each time is not what I'd call fun, but that is how JLR makes their money.
Old Apr 30, 2023 | 10:44 AM
k9gears's Avatar
I saw a few hacks to at least get it into or out of each gear.
It is in Russian but the tutorial is straight forward
For anyone needing this help
amer_qureshi
Jul 10, 2024 02:03 PM
ponderosajack
May 15, 2021 09:59 PM
JWBennett
LR4
Feb 2, 2021 07:20 PM
DavidM
Sep 7, 2010 12:54 PM
ericandersontn
Sep 21, 2008 01:30 PM
