99 range rover 4.0 SE Suspension Help
Had my local mechanic change out the suspension from the EAS to a standard coil suspension. Having issues with the front driver shock, whenever I drive through a pot hole or bump it clunks really hard. Thinking I need to change the shocks since it has some regular shocks from O'reilly, I don't believe that the shocks were replaced from EAS to standard coil suspension. Any suggestions on the model/catalog/brand that I should be looking for? also should I also need to change the back shocks as well?
Thanks
Thanks
Ideally you want shocks made for the coil suspension, front and back. Check your bushings and sway bar links for the sound. Make sure there’s a rubber spring isolator on the coil to the frame mount. Also check the condition of the bump stop. They can deteriorate to almost nothing, especially if they are ever driven on the bump stops much
