Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
Bad heater core temp sensor?
Old Dec 25, 2020 | 03:27 PM
Greendisco12's Avatar
Default Bad heater core temp sensor?
What symptoms are generally associated with a bad heater core temp sensor? Pretty sure mine is bad, and doesn’t seem like I’m getting full heat in this cold weather. Pretty much every component of the cooling system is new and I bled the cooling system several times. Last owner says the heater core was recently recently replaced.
Old Dec 28, 2020 | 12:57 PM
the temp sensor i was referring to is the one that clips on to the hard pipe of the heater core
rickroverover
Aug 25, 2020 10:39 AM
LR03NJ
Oct 19, 2017 06:04 PM
logicmike44
Feb 27, 2011 07:38 PM
DiscoDad
Dec 5, 2010 04:58 PM
tre976
Feb 18, 2008 09:22 PM
