Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
Traction Failure , pointers please
Old Jul 17, 2021 | 08:08 AM
oxtobyd's Avatar
8th Gear
Default Traction Failure , pointers please
Hi everyone, new here with a 2000 4.6 P38. It’s recently throwing a Traction Failure message and orange light (but not ABS light), I’ve got a healthy fully charged battery, changed the abs pump relay (just in case), it throws the error while stationary and sometimes when moving. Today I did a clean and added some air into one tyre which oddly got rid of the fault for a few miles but then returned. Tried to read codes with RWS software but nothing, and went to local garage who used their Hawkeye Pro and it could not pull any codes either, but still the Traction Failure fault… any pointers folks since I’m guessing this is an MOT failure and it’s due in 2 months!
Old Jul 22, 2021 | 10:57 AM
Harvlr's Avatar
A low tyre does make sense as ABS sees a different speed between the wheels. I would have thought that RSW would read any fault that existed. Did you try clearing the faults even if none were listed? I’m assuming it still shows the light when you’re moving (it’s normal for the light to be on when you first drive away until you reach a certain speed, IIRC 7kph).
Old Jul 22, 2021 | 11:00 AM
oxtobyd's Avatar
8th Gear
Pleased to say since having put air in the tyre and after a few miles of driving the TF light finally went out and has stayed out, since no hard faults were recorded so made me think it wasn't anything serious, and it seems like it was just down to the low tyre pressure on one side, which makes sense. Wish i'd explored this sooner, but hey u live and learn.
Old Jul 22, 2021 | 10:59 PM
Harvlr's Avatar
Good to hear. It sounds like all is well.
CanadianRover
Jan 8, 2020 01:05 PM
tchaudhry10
Jun 3, 2015 06:10 AM
nazdackster
Oct 7, 2009 09:21 AM
wizardmagu
Apr 23, 2009 01:38 PM
thelokolobo
Mar 10, 2009 05:34 PM
