Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Bleeding Dynamic response.
Old May 25, 2022 | 02:52 AM
Patrick Cox's Avatar
Default Bleeding Dynamic response.
Apart from the instructions given in the w/shop manual for bleeding the dynamic response system , is there a work around . I have just replaced the pipes on the front section on my RRSport and I need a special tool. I like to do everything myself but this time it looks like I'm stuck.Also need to replace the pressure transducer in the valve block on the system , does anyone know where I could source this as it appears to be quite pricey. Fault C1A09-16, perhaps this is inhibiting the system module to activate the actuators. Perhaps someone can help me please
So moving on a bit , I have discovered , someone has by passed the pump for dynamics with a shortened belt, I have replaced this and fluid is circulating and now get two different codes while driving .C1AA20-64 , U0132-87 Not sure why was hoping for Dynamic related codes now that the pump is working. Maybe I confused the modules .I looked up the code for compressor relay and clearly not that , I have read that they need replacing from time to time . Where is this relay , just in case.
Old Jul 17, 2023 | 10:23 AM
rangerover22's Avatar
Do you no what size the smaller belt was
Old Jul 17, 2023 | 12:22 PM
No , I don’t off hand but it’s in the door of my RR , I’ll measure , there is a part number , I’ll look.
PAT
Old Jul 26, 2023 | 11:22 AM
Sorry , you probably worked out what this belt measures now , I forgot.
Its approx 500mm Int.diam. Also information on the belt is a Gates brand and part number is 6PK1043
Hope thats useful/
dmccoy1132
LR4
Aug 8, 2024 12:03 PM
04duxlr
Dec 29, 2013 01:09 PM
drowssap
May 16, 2011 07:41 PM
Disco00
Apr 11, 2011 10:15 AM
franz
Mar 24, 2011 03:46 PM
