Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Charcoal canister..2011 RRS HSE
Old Sep 17, 2019 | 09:44 PM
ssonal98's Avatar
Default Charcoal canister..2011 RRS HSE
Howdy! Have a 2011 that started with the check gas cap light to full on check engine light....smelled gas too outside the vehicle. Replaced the fuel pump because the casing had a crack in it. Thought it was all clear so took it in and failed emissions test. Oh did I mention I can't pump gas without it clicking....so takes me a bit to fill the tank. Question is will replacing this canister clear this issue? I'm thinking it will but also looking at the fuel filler neck to clear the gas pumping issue. Anyone deal with this before?
Old Sep 21, 2019 | 08:39 AM
LR Techniker's Avatar
We have seen several and we systematically tested each section of the fuel system for blockage, only to end up replacing the canister on each of those. We also do the DMTL Pump while out. On some models they are attached to the canister, on others they are remotely mounted.
Old Sep 21, 2019 | 11:45 AM
ssonal98's Avatar
Canister will be replaced this week. I was told the fuel filler neck needed to be replaced as well due to the rollover valve being in the wrong position. I'll update once the repairs are done!
Old Sep 27, 2021 | 04:09 PM
David M Cerame's Avatar
Default Where is it?
Where is the charcoal canister on the L320?
pgk
Jun 5, 2014 11:43 AM
Lawndart
Apr 27, 2014 08:14 PM
jigray3
Sep 4, 2012 02:07 PM
honda50r
Jun 13, 2011 05:58 PM
landroverlady
Jul 9, 2009 11:26 AM
