Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
help! bad ecm?
Old Aug 1, 2023 | 09:58 PM
nm50's Avatar
5th Gear
Default help! bad ecm?
Hi guys! Looking for some guidance. I have a 2008 RRS SC that died on the way to work. It would subsequently start, run, stumble, stall multiple times. Jumped the fuel pump relay, same behavior. Replace the pump, after running initially for a few minutes, same behavior. No related fault codes on IID Tool. Is it possible ECM is bad and not throwing a code? Am I missing something?
Thanks!
Francis
Old Aug 7, 2023 | 01:08 PM
L33DiscoII's Avatar
Maybe try disconnecting the MAF sensor which will make the computer go to a "safe default" mode. See if it runs. It could be a bad CPS but I'd think that'd set a code. Do you have 12v+ when it's running? Did you replace the fuel filter?
redrover75
Jul 2, 2023 12:57 PM
84crawling
Dec 22, 2021 03:36 PM
30more
Jul 3, 2012 10:23 AM
bilmgl
Oct 18, 2011 08:36 AM
kenk
Jun 26, 2010 08:34 PM
