Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
No Drive! No Drive Engagement
Old Jul 30, 2020 | 10:12 PM
SecondNature's Avatar
Default No Drive! No Drive Engagement
Hello, i am new here, I I own a 2005 Lande Rover Range Rover.4.4. I recently had an Alternator go out. the vehicle was running fine, no issues no check engine lights nada. 85k Miles So, I Replaced the Alternator. I fill it up with coolant. Go to take it for a drive. The vehicle goes in reverse for about 100 feet ( i was on the street and actually fixed it in a parking lot ) The vehicles all of the sudden just revs in Reveres. So I put it in Drive, still nothing. I push the vehicle back into the spot I came from. I took a look at the shifter cable, nice works great. Come back in try it again put it in reverse and then drive, nothing .go to put it in the park and i hear a grinding sound like when a car is moving and you throw it in the park. i had someone hold the brake and put it in Revere and Drive, i see the from prop shaft spinning but no engagement to the front Diff. They up it in drive it freely spins one way then reveres spins another way, but no engagement like it's in neutral. I put my hand on the rear driveshaft, it is just as it would be in the park. No movement at all. I am so confused. i did the #37 rest with the fuse. Still nothing Nothing at all. Did the Alternator surge and blow the Transfer case ECU? Relays? i have no idea what else to look for. So confused. the vehicle was just perfect. I did notice a few times that the low gear light was flashing but would stop after i shut off and restarted.I hope someone can help!
workinghard1713
Jun 22, 2023 10:34 PM
cappedup
Oct 30, 2014 05:30 AM
texgant
May 2, 2013 11:16 AM
wess98range
Mar 5, 2009 11:04 AM
philo73
Dec 17, 2007 02:00 PM
