P0089(64)...again
Old Aug 12, 2022 | 04:56 PM
jahummer's Avatar
Default P0089(64)...again
Nearly a year ago I was having this issue, intermittently. Replaced the fuel rail pressure sensor and still had the DTC. Replaced the low pressure fuel pump in the tank and the DTC went away...until now. About a month ago the main dealer replaced the fuel filter & flange under the JLR recall and everything was fine. In fact it may not even be related. But this time the DTC's no longer intermittent and it will not go away. Anyone have ideas?
Old Aug 19, 2022 | 04:53 PM
jahummer's Avatar
Default Resolved
Silly me I'd forgotten there was a TSB for this issue when I first had the problem a year ago. At that time it was believed to be and resolved by replacing the low pressure fuel pump. This time I took it to the main dealer and the lead tech recommend performing the PCM calibration update and several hundred miles later, the code's still not returned.
Old Jun 13, 2024 | 11:58 AM
jahummer's Avatar
And it's back....
Old Dec 27, 2024 | 09:11 PM
msh03046's Avatar
I'm looking at a 2016, was supposed to pick it up tomorrow, and I found out it's throwing this code. Did you ever find a resolution?
Old Dec 28, 2024 | 07:59 AM
jahummer's Avatar
Replaced the low pressure fuel pump for a third time and fuel filter for the fourth time and the code's gone BUT can't confirm it won't return as cylinder 1's misfiring again 10K miles after replacing plugs. coils and injectors.
m1rc
LR2
51
Sep 6, 2022 06:23 PM
tricey27
Jul 18, 2020 07:42 PM
Omorin34
Jan 31, 2016 10:22 PM
JCSNGL10
Dec 6, 2011 12:20 AM
Dodger
Mar 9, 2011 09:32 PM
