Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Suspension issues
Old May 9, 2026 | 07:02 PM
Sonny's Avatar
4th Gear
Default Suspension issues
Hello everyone.
I have a Range Rover sport 2008
So my problem is that when I try to raise or lower the vehicle it goes into extended height and stays there. If I try to lower it to normal height, the car will lower a little, then I get the "suspension in extended height" message and goes back into extended. Also only my rear goes into extended, the front raises/lowers normally. I tried to do a height calibration, but during the calibration when the car goes into off-road height and then back to normal height, I get the "extended height message" and the car raises again, so I cant finish the calibration. The only way to bring it down to normal height is to pull out the relay and drive until I get the "suspension fault, normal height only" message and the car goes back to normal height. There are also no fault codes at all. All help is appreciated.
Scandinavian outdoor
Sep 9, 2025 08:45 AM
Jondl18
Oct 16, 2023 05:12 PM
Chum
Oct 6, 2021 06:35 AM
Curtis Hudson
Nov 29, 2017 07:38 PM
Manicoti
Jan 23, 2011 09:22 AM
