Suspension issues
Hello everyone.
I have a Range Rover sport 2008
So my problem is that when I try to raise or lower the vehicle it goes into extended height and stays there. If I try to lower it to normal height, the car will lower a little, then I get the "suspension in extended height" message and goes back into extended. Also only my rear goes into extended, the front raises/lowers normally. I tried to do a height calibration, but during the calibration when the car goes into off-road height and then back to normal height, I get the "extended height message" and the car raises again, so I cant finish the calibration. The only way to bring it down to normal height is to pull out the relay and drive until I get the "suspension fault, normal height only" message and the car goes back to normal height. There are also no fault codes at all. All help is appreciated.
