Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
How to OPEN the Sliding type of Seal Door Jamb Rubber Grommets found in the L494?
Old Aug 8, 2024 | 05:50 PM
EdwardRRS's Avatar
Default How to OPEN the Sliding type of Seal Door Jamb Rubber Grommets found in the L494?
How to open and get through the Front Door Jamb Sealed Rubber-
Grommets to the Engine bay?
Any pictures or videos would be greatly appreciated.
As you can see from picture number 2, I tried to Lift a slider, but I have no idea what to do next. I don’t want to mess it up. Does anyone has a picture? or video? I’ll have to wait until I know how to open it and seal it afterward because I might create water leaks into the wiring when it rains, if I don’t know how to seal it back.
Thank you.
Old Aug 10, 2024 | 03:29 PM
EdwardRRS's Avatar
I went online to a used parts store and I found the Door Jamb Rubber Grommet. It seems there isn’t much space to run Speaker and Camera Wires through the Grommet Connector.
I still need to understand how to disconnect the Grommet connector shown in the picture. There is this slider, which I pull up just a bit in the previous picture of days ago. I think I should pull the slider up further.
I fear that if I’m wrong I will be causing water leaks when it rains.
If you have done similar work through a similar grommet. Is there a way to run Speaker Wire, and/or DashCam wires through the Grommet?
XplusYplusZ
Dec 28, 2023 12:28 PM
LeakyDisco
Dec 23, 2021 12:23 PM
TimInNova
Jun 28, 2021 08:12 PM
jhobbs1824
Apr 22, 2016 09:34 AM
Eugene
Jul 22, 2011 11:02 AM
