Range Rover Velar Talk about the Land Rover Range Rover Velar within.
Fan turns on after Engine off
Old Mar 7, 2018 | 05:48 PM
MNK's Avatar
MNK
Default Fan turns on after Engine off
I just purchased my Velar 2.0 250HSE, and noticed Fan turns on after engine off like a plane fan for 1-2 max and than turns off slowly. Is this normal behavior?
Old Mar 7, 2018 | 06:38 PM
Many vehicles will run the cooling fans to continue to drop the coolant temp for a short time after the vehicle is shut off. A few have electric coolant pumps to continue to circulate the coolant as well to reduce heat soak.
Old Mar 7, 2018 | 06:47 PM
MNK's Avatar
MNK
Thx mate, Ill try to test it tmw morning by turning the engine on for a min and than turning it off.
Old Mar 7, 2018 | 07:01 PM
need to get the temp up to a certain point for that to engage. Looking at the temps where you are at, if you are in traffic it will likely warm it up enough to trip that feature
Old Sep 17, 2020 | 12:35 AM
mamawolf_'s Avatar
3rd Gear
I just found out today that there was a recall on the Velar fan on excessive noise, might want to check it out at your local Land Rover
Old Sep 25, 2020 | 05:13 AM
Nuwandika's Avatar
3rd Gear
OFSA N451 coolant pump operation . check with your dealer .
Lord Wert
Jul 4, 2013 07:52 AM
'BamaBoy
May 24, 2012 12:45 PM
TxDiscoII
Aug 15, 2011 03:37 PM
btbaus
Sep 28, 2009 03:17 PM
LordOphidian
May 15, 2008 08:32 PM
