shuttle valve
Old Mar 13, 2014 | 08:35 AM
briandmozy's Avatar
Default shuttle valve
hi all, i have a disco 2 that has the 3 amigos steady on and has been for a while. i have recently tried the repair of the wiring on the vale itself with no luck. when i used my meter to test the valve, i did not get correct ohm readings when in open or closed positions.
would like to see if anyone has a shuttle valve that is getting correct readings that theyre willing to part with.
thanks in advance
Old Mar 13, 2014 | 11:39 AM
DiscoJ's Avatar
I believe the shuttle valve switches are what you're referring to. Atlantic British sells new assemblies... ABS Modulator Shuttle Valve Switch (Part # SWO500030) - Land Rover hydraulics from Atlantic British
I would recomend you go ahead and inlist option 'B' (modulator ground bypass) while your at it as this deals with the root cause of the 3 Amigo issue. ABS Mod - LAND ROVER CLUB V.I.
Old Mar 14, 2014 | 04:47 AM
briandmozy's Avatar
Thanks for the info. I will check AB for the part. I have already done the "B" repair on the one in the truck now however when I checked the valves with a meter, the resistance was not reading the correct numbers making m believe that the valves are bad to begin with.
Old Mar 14, 2014 | 12:25 PM
DiscoJ's Avatar
Yeah, that makes sense. I think when you replace the valve switches, you'll be all set.
Good Luck!
bosshogt
Feb 2, 2012 06:52 PM
aarongregor
Nov 14, 2011 08:31 PM
majrmike
Oct 9, 2007 03:13 PM
Different Drummer
Aug 7, 2006 09:28 AM
rovernbama
May 9, 2006 11:12 PM
