Series I, II, IIa, III Land Rovers For all Series Land Rovers
Series III low power at higher gears
Old Apr 2, 2025 | 01:05 PM
Dougk's Avatar
Default Series III low power at higher gears
Can’t pin down the issue with low power and back firing above 40 mph. New muffler assembly, clean points, fuel pump working great, carb working fine. Puzzled.
Old Apr 2, 2025 | 03:02 PM
Harvlr's Avatar
There are a number of possibilities. If, as you say, the carb is fine, it’s likely ignition. Bad spark plugs or wires, bad or mal-adjusted points, bad rotor or cap, bad coil. I’d start with looking at those items.
Old Apr 2, 2025 | 03:24 PM
Dougk's Avatar
Thank you so much. I will double back on ignition.
gmuiter
Dec 17, 2024 09:25 AM
Marnus
Dec 16, 2024 08:42 PM
wncrrcSIIA
Nov 29, 2022 04:24 PM
jayw
Oct 25, 2017 04:40 AM
toad69
Mar 18, 2006 04:35 PM
