Removing a destroyed head bolt -- any suggestions?
1999 D2, but that's largely irrelevant.
The flats on one of my head bolts have rounded off, so it's at full torque and I can't loosen it. Of course it's one of the bolts at the bottom of a valley, so I can't get a grinder or Dremel down there. I have the other bolts still torqued down to try and reduce the tension on it, but I'm not having any luck getting it to move.
I have drilled into the center of the bolt but I don't want to run the risk of going astray and damaging the head. I don't have any faith that an E-Z Out will be able to handle the necessary torque. Does anyone have any suggestions?
Of course. Two different ones. And a 12-point 16mm socket along with a regular 6-point. Two of them split. And there's not enough head left to be able to get a socket onto it any more.
Craftsman makes a damages bolt/nut remover. You hammer it on the bolt head. It will cut into the damaged head, and continue to dig in as you apply torque.
Hmmm. I'll take a look at those. There's almost nothing left of the head though. I'm at the point where I think I'll just have to use a pinpoint grinder on my Dremel to chew away enough of the head that it collapses.
Well, I managed to get the bolt out, after much careful grinding and drilling and aiming with a narrow cold chisel.
The two sockets in the background are the ones that split when I was first trying to remove it, when the bolt was still mostly intact.
Damage to the head itself is minimal, thankfully.
