So what did you do to your Disco today?
#3941
#3942
#3943
https://www.amazon.com/Motorad-2000-...180+thermostat
Decent price if you have prime. I went lazy and used some rtv on the housing to put it back together. The gasket I ordered was wrong. It's pretty easy to swap out. Loosen hose clamp on upper hose. Remove two thermostat housing bolts. Remove housing, pull out thermostat. Clean mating surfaces. Put her back together. Refill with coolant.
#3944
Replaced original turn signal stem with new. Had no tail lights or dash lights when I turned on the head lights. Oddly, I did have both dash and tail lights when using just the 'city lights' .
Also went to the hydraulic shop and bought new o-rings for my bottle jack.
#3945
#3946
Well I buttoned up the headliner tonight. No more water leaks. No more binding sunroofs. No more sagging fabric. Led cargo light securely attached to headliner. Flashlight mount securely fastened to headliner. Switch for roof lights mounted next to homelink. Also wired in a remote module for the roof lights. That'll be nice to not get blinded when walking back to the truck after hooking up the winch rope
love the bed liner / head liner! I used same prices but looks like you paid a little more attention to details.
Loooks great
MrValingo (12-08-2016)
#3949
- swapped in new rear pads and the squeal is gone. Replacements are Wagner Thermo quiet pads (MX518) https://www.amazon.com/dp/B000CQTO6I...ermoquiet+pads .
- removed front seat bottom covers and dropped them off at the upholsterer for repair.
#3950
