So what did you do to your Disco today?
Old Dec 4, 2016 | 08:11 PM
  #3941
MrValingo's Avatar
No I went with the 82c (180f) thermostat even though it's winter here in Wisconsin. But the temps were good, 177-195f at the highest while I picked up the Christmas tree
Old Dec 4, 2016 | 08:47 PM
  #3942
stillruns's Avatar
10-4. Suggesions on where to order and difficulty of installation? Thanks
Old Dec 4, 2016 | 09:02 PM
  #3943
MrValingo's Avatar
https://www.amazon.com/Motorad-2000-...180+thermostat
Decent price if you have prime. I went lazy and used some rtv on the housing to put it back together. The gasket I ordered was wrong. It's pretty easy to swap out. Loosen hose clamp on upper hose. Remove two thermostat housing bolts. Remove housing, pull out thermostat. Clean mating surfaces. Put her back together. Refill with coolant.
Old Dec 5, 2016 | 10:23 AM
  #3944
WaltNYC's Avatar
Replaced original turn signal stem with new. Had no tail lights or dash lights when I turned on the head lights. Oddly, I did have both dash and tail lights when using just the 'city lights' .
Also went to the hydraulic shop and bought new o-rings for my bottle jack.
Old Dec 7, 2016 | 04:47 PM
  #3945
stillruns's Avatar
Pre-winter detail. Also got a new battery and ordered a new reservoir tank as the current one has a crack and leaks like a Discovery sunroof.
Old Dec 7, 2016 | 05:16 PM
  #3946
cptbrd's Avatar
3rd Gear
Well I buttoned up the headliner tonight. No more water leaks. No more binding sunroofs. No more sagging fabric. Led cargo light securely attached to headliner. Flashlight mount securely fastened to headliner. Switch for roof lights mounted next to homelink. Also wired in a remote module for the roof lights. That'll be nice to not get blinded when walking back to the truck after hooking up the winch rope
love the bed liner / head liner! I used same prices but looks like you paid a little more attention to details.
Loooks great
Old Dec 9, 2016 | 12:38 PM
  #3947
CPTLOU's Avatar
With regret, I've decided to put my SE7 in the chopping block and finish up my 00' TreK.
Attached Thumbnails So what did you do to your Disco today?-20161201_115139.jpg   So what did you do to your Disco today?-message_1469140860089.jpg
Old Dec 11, 2016 | 10:45 PM
  #3948
CMWassam's Avatar
5th Gear
New water pump, upper and lower rad hoses, serpentine belt, therm
Old Dec 13, 2016 | 06:50 AM
  #3949
WaltNYC's Avatar
- swapped in new rear pads and the squeal is gone. Replacements are Wagner Thermo quiet pads (MX518) https://www.amazon.com/dp/B000CQTO6I...ermoquiet+pads .
- removed front seat bottom covers and dropped them off at the upholsterer for repair.
Old Dec 13, 2016 | 11:30 AM
  #3950
fishEH's Avatar
Can you p back when you get the seat bottoms back? I'm curious what something like that will run. I kind of like that idea more than trying to retrofit something into by '94 and '95 D1's.
