#3771
Then my lettering will be sideways...haha! Cool man. Didn't think about that. I used my dremel as well to get this one to fit vertically. Fit's snug. Sliced off that blank tab so it can fit. Not sure what that is for??
#3773
But yeah, everything is soldered. I hate crimp connectors and such
#3774
Mine is doing the same. Squealing bad on start up then settling down. But intermittently chirping or squealing once warmed up. This could be the culprit. Need to hunt it down. Thanks!
#3775
Well, today i didnt do squat. But in the last week ive installed a 180 oem tstat, adjusted the top of both driver side doors so they close all the way, switched around the front and rear window switches (i like the fronts on top), epoxied the window switch panel in place since only one screw tab was left, and found out my ac works...if the line to the accumulator didnt leak and the ac fan worked.
#3776
