Old Mar 12, 2017 | 03:14 PM
  #3771
rossagge's Avatar
Originally Posted by zoltan7
You can turn that switch side ways, drill out that remaining raised section and run it in perfectly flush right there.
That's exactly what I did with my LED bar switch
Just use a dremel and be careful not to nip off those tabs on the back
Then my lettering will be sideways...haha! Cool man. Didn't think about that. I used my dremel as well to get this one to fit vertically. Fit's snug. Sliced off that blank tab so it can fit. Not sure what that is for??
Old Mar 12, 2017 | 03:43 PM
  #3772
zoltan7's Avatar
No idea lol it was just an abscess for me
Old Mar 12, 2017 | 05:59 PM
  #3773
Twix's Avatar
Originally Posted by Friday Night Disco
How did you wire them up (i.e. vampire clips to existing reverse lights, leverage rear fog, tapped into trailer plug)?
I cut and soldered into the reverse lights in the rear, the bar is wired to the battery with a supplied switch that I mounted on my centre console until I get the factory AUX switch.
But yeah, everything is soldered. I hate crimp connectors and such
Old Mar 12, 2017 | 07:25 PM
  #3774
rossagge's Avatar
Originally Posted by JUKE179r
I had a loud squeal coming from my 2001 Disco's engine pulleys.
Found it! The plastic belt tensioner pulley had cracked. The bearing was loose and floating around inside of it.
Mine is doing the same. Squealing bad on start up then settling down. But intermittently chirping or squealing once warmed up. This could be the culprit. Need to hunt it down. Thanks!
Old Mar 12, 2017 | 08:15 PM
  #3775
MrValingo's Avatar
Well, today i didnt do squat. But in the last week ive installed a 180 oem tstat, adjusted the top of both driver side doors so they close all the way, switched around the front and rear window switches (i like the fronts on top), epoxied the window switch panel in place since only one screw tab was left, and found out my ac works...if the line to the accumulator didnt leak and the ac fan worked.
Old Mar 13, 2017 | 10:59 PM
  #3776
Maa45069's Avatar
Got the Wifes 04 back from mechanic with new head gasket installed! happy but have noticed a new vibration after 65mph.... on to the rotoflex!.... I hope....
Old Mar 14, 2017 | 04:48 PM
  #3777
Jeff Blake's Avatar
BFG a/t ko2 235/85/R16 mounted onto new Terrafirma beadlock wheels
Old Mar 14, 2017 | 04:58 PM
  #3778
JUKE179r's Avatar
NICE!!!!
Old Mar 15, 2017 | 08:58 AM
  #3779
dgi 07's Avatar
Doing the Rover walk of shame.
PSA for the day, Lube your transfercase linkage.
Old Mar 15, 2017 | 01:31 PM
  #3780
mollusc's Avatar
When my t-case/range linkage slipped off the spline when I was testing it in a parking lot, I just ripped out the center console there and then so I could fix it!
