Old Apr 24, 2017 | 12:36 AM
  #3921
MrValingo's Avatar
Hand wash n wax. Installed the garage door opener from my 98. Discovered the PO left the hardware for the positive battery terminal out. Used a large nut and a step drill the kinda give it a cone shape. Then ground the head of a stainless machine screw into a rectangle. Put it all together now she's nice n tight
Old Apr 24, 2017 | 04:27 PM
  #3922
Friday Night Disco's Avatar
replaced serpentine belt this weekend
mounted rear step this weekend (I have short legs)
replaced t-stat a few minutes ago
Old Apr 24, 2017 | 04:30 PM
  #3923
Got both sunroofs working. The rear would open but wouldn't close. Turned out it was grounding out close to the sunroof control module compliments of the overhead map storage. Don't know if it was me or the previous owner but taped it all up and made damn sure it wasn't gonna have a screw going through it again.
Old Apr 25, 2017 | 04:39 AM
  #3924
Default Jeff.
These are the straps, four in a bag. They do not ratch, you pull them tight and then the handle levers over to tighten them more.
We have some different styles, but I was short on time yesterday...so searching through binds was limited.
Old Apr 25, 2017 | 07:53 AM
  #3925
Zonk872's Avatar
Swapped 03' roof rails with 04'... yup have rear AC 🙄. Swapped hood due to clear coat being bad... swapping front passenger fender today.
Old Apr 25, 2017 | 09:13 AM
  #3926
Joe!'s Avatar
Wonder where you got all those nice parts? Lol
Old Apr 25, 2017 | 07:50 PM
  #3927
Zonk872's Avatar
A solid Rover friend who goes out of his way to help a friend out. Above and beyond...
Old Apr 26, 2017 | 06:23 AM
  #3928
CollieRover's Avatar
I fixed my headlights, well, I have them in solid. The tabs on the are long gone and had to drill out the top screw nuts and plasti-weld some new ones in. Now to get them clear again.
Old Apr 27, 2017 | 04:46 PM
  #3929
After finding out the allmakes rubber bushings wouldn't fit the radius arms, I picked up a set of the Britpart Poly bushes. Arm to axle popped in super easy.
Arm to frame, not so easy.
I made this stupid contraption - hitch vise plate, trailer hitch, some 2" fittings, a strut compressor bolt, and a breaker bar. I thought it was going to work - had the bushing in over half way... but it just won't go any further. A press is needed... back to the shop
Old Apr 27, 2017 | 09:01 PM
  #3930
Disco Dad's Avatar
Default Saudi Grill!
I've been wanting to do this for a while. I think it turned out great!
Attached Thumbnails What did you do with your DII today?-img_0255.jpg   What did you do with your DII today?-img_0260.jpg   What did you do with your DII today?-img_0261.jpg   What did you do with your DII today?-img_0262.jpg   What did you do with your DII today?-img_0263.jpg
