Old Oct 12, 2015 | 11:18 AM
  #2921
hokkabaz's Avatar
I was messing with the door lock actuator this morning and realized something new.
my door handle is already disconnected from the actuator.
when i lock the car(from the remote) i try to open the door manually by putting my hand into the door handle hole and push/pull the metal stick and it doesnt open the door, which is good because the car is locked anyway.
Once I unlock the car(from the remote) i still cant open the door by messing with that stick.
but if I open the door from the inside door handle for once, then i can close the door back and open it from outside from that stick 1000tines in a row without failing once!
I dont get it
Old Oct 13, 2015 | 04:46 PM
  #2922
sstevensonm's Avatar
Default WNLRR Rally
Just got back from the WNLRR Rally. What a great time. Took my 4 year old Grandson. Our first time camping without Mom or Nana. 240 vehicles lots of new friends, lots of trails. What a great time
Old Oct 15, 2015 | 02:49 PM
  #2923
hokkabaz's Avatar
I cant believe that cleaning the spark plugs did turn off the flashing CEL and rough idling!!!! Just the o2 errors are left.
I cant wait to get off from work and drive it!! I will try not to run over every object I see, but it is so tough not to, with this machine! :/
Old Oct 15, 2015 | 09:26 PM
  #2924
Roto's Avatar
Today I installed D1 wiper arms with Bosch Icon blades and heated seat buttons. Also got a rubbermaid tote for the back to hold all of the spares.
Old Oct 17, 2015 | 01:23 PM
  #2925
hokkabaz's Avatar
She is about to get a haircut! I am planing to cut the lower part of the both sides of the bull bar with a dremel while the bumper is still on its place, and I will try to figure out a way to somehow glue and spray paint the upper part. Lets see how ugly it will look!
Attached Thumbnails What did you do with your DII today?-img-20151017-wa0007.jpg
Old Oct 17, 2015 | 07:47 PM
  #2926
Twix's Avatar
Replaced my right front wheel hub. FML that nut sucks to take off! I bought a 4ft breaker bar for the job, and I had to jump on it to get it to move. Hopefully now I can get my codes cleared and hopefully the 3 amigos will be gone.
Old Oct 18, 2015 | 06:46 PM
  #2927
thesoundguru's Avatar
Default This oil pump will self destruct in 3..2..1..
Went to go to church today and the oil pump decided to self destruct. Now comes the fun part of the tear down to see what all is going to have to be replaced. I'm just really glad it happened in my driveway instead of on the highway with my wife and 2yr old in the truck. Funny part was my son has figured out the gas pedal and floored it next thing I know I hear a lot of rattling and have no oil pressure.
By the way I know the problems the 03 has with the pump, if I were to change the front cover with a different model year front cover would that help at all with the problems?
Old Oct 18, 2015 | 07:40 PM
  #2928
lordmorpheus's Avatar
My Landy: drove the family to the local 15 acre corn maze: The Corn Maze | Shryocks Callaway Farms
Landy I am working on for an overheating problem: Troubleshot why the OBD port was not powering my scanner. Pin 16 was only putting out 8.5V. Broke out the RAVE wiring diagram, verified fuse 20 was good, as was fusible link 3 under hood. Dropped the blower motor and opened the 2" diameter wire bundle running behind it along the back of the foot well. Connector C0289 looked ok, but found the scanner came to life as I flexed the wires going to it. I know it's not the "proper" repair, but if I tape it back up in the flexed position, the OBD port works perfectly, so I'm going with easy as opposed to painstakingly tedious to check continuity of each wire. '
This vehicle has been parked in a friend's driveway the past few years, and I suspect a mouse took up residence in the dash from the looks of the blower wheel. Surprisingly don't see any damage to the wiring though. Small Blessings.
Tomorrow I'm going to replace the functional thermostat in mine with a TD5 185* unit, then swap out the Motorad in the basket case with my old functional one to see what, if any, difference that makes.
Attached Thumbnails What did you do with your DII today?-2015-10-18-11.06.19.jpg
Old Oct 21, 2015 | 01:14 PM
  #2929
TheSloth's Avatar
4wd High
Broke my alpine window. Have glass and am going to attempt to do a write up on it.
Old Oct 21, 2015 | 03:09 PM
  #2930
ls1morethanyou's Avatar
nice! i replaced mine with plastic
