throttle body cleaning, 2001 D2
This was easy to do. Using CNC Throttle Bottle Cleaner, and placing a rag bellow the opening, a couple of sprays and cleanup with lint free cloths, did the job. I did manage to clean the contact area between the body and the gate, but only facing outward.
Is there a simple way of removing the throttle cables without the need of getting feeler gauges to reset them? I would like to get the job done right. Thanks for all comments.
Todd
Todd
Shouldn't ever need a set of feeler gauges to adjust the throttle cable/cruise control cables on a D2. You just adjust them with a pair of 13mm open end wrenches. I'd make each one sit about 2mm away from the plate. That way you'll have excellent throttle response and your cruise control won't surge.
