Camel pin tow hitch for rear bumper
The hitch and galvanized backing plate are only for attachment directly to a bumper, IE camel style mantec fronts or the special vehicles discovery rear bumpers.
You are using the RN hitch adapter and so do not need the backing plate (not bolting through a bumper or steel plate). Remove the galvanized plate, set aside for if you ever do a bumper mount, or need to sell the tow jaw. Front part of jaw will bolt directly to hitch receiver piece.
Thanks for the pointers. Much appreciated.
5 ton jaw (4 bolt) is for rear bumper
EDIT: the factory bumpers for camel might have only been modified in the center portion with a big welded insert, but now I cannot recall.
Defender rear cross member however has provisions for the 4 bolt style hitches either nato eyelet type or dixon bate pin type, which also need backing plate
jsaenz
04-13-2017 09:02 AM
craigalmaguer
03-21-2016 02:44 PM
