Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Discovery LED Upgrade
Old Jul 4, 2008 | 09:50 PM
99LRDisc's Avatar
Default Discovery LED Upgrade
Size:  22.6 KBName:  led3.jpg
Size:  17.2 KBName:  led1.jpg
Old Aug 14, 2011 | 09:20 AM
richyrich0607's Avatar
Very nice!
By any chance would you be able to help me out with the type of bulbs you used? I want to do the same to my 02 Discovery.
Thanks!
Old Aug 14, 2011 | 09:43 AM
superbrightleds.com has ones that will plug in (called festoon), I also found some generic in the blister pack aisle at one of the auto parts stores, I soldered mine in. Much more light, and way less amp drain on MFU. And my MFU had failed because the big transistor in it that is used to dim the lights has no heat sink, had hole melted in the plastic MFU case. Engineers!! Being an old guy, I need all the light to check my Depends after first encounter with the "Death Wobble".
Old Aug 14, 2011 | 07:37 PM
dgi 07's Avatar
WAIT....dont order yet....i just went thru this. there are two different bulbs for the interior lights....the center one you can get at superbrightleds. its a 36 mm bulb i believe. you are also gonna need a 39-40mm feston for the front and rear as well.
Old Aug 14, 2011 | 07:45 PM
dgi 07's Avatar
to the OP, what bulb type did you us for the vanity mirror bulbs?
Old Aug 15, 2011 | 09:19 PM
Hello dgi07,
So is there any way you could list out the bulbs you used and the location! Thank you...that you be of very great help so I know exactly how much of each bulb to buy.
And I'm also interested in what the vanity lights are also.
Old Aug 16, 2011 | 08:33 AM
dgi 07's Avatar
Originally Posted by richyrich0607
Hello dgi07,
ok, if you go to superbrightleds, and plug your truck into the bulb finder, you will see the one bulb they listed for all dome lights. It will only work for the center light. you will need a feeston type bulb thas about 3 mm longer than the one they have listed. i didnt do the vanity lights because they are meant to be softer lights for a woman to adjust her makeup as needed. and as you can imagine, my wife frequently likes to ride in my truck so i left those alone.
Old Dec 13, 2011 | 01:39 AM
Memroyfoam's Avatar
6th Gear
Just an FYI...
I used the 3710-CWHP3 for all 3 dome lights from SUPERBRIGHTLEDS.COM. They fit, but you might have to spread the connectors just a bit (not much). I was trying to save money (but in hind sight) i probably would have bought the 3710-xHP6 for the very back and middle dome light. Hope this helps.
here are the links:
3710-xHPx High Power LED Festoon Bulb Specifications
Old Dec 13, 2011 | 01:46 AM
Memroyfoam's Avatar
6th Gear
BTW...
I have a Disco 2 2002.
@ dgi 07, I agree about the vanity lights. ...they are for the ladies and softer light means "happier reflection" lol. However you could maybe try the WARM WHITE LEDS.
Old Dec 13, 2011 | 02:22 AM
Memroyfoam's Avatar
6th Gear
....also
Is your truck an LSE? Curious because it seems by your pictures you have lights in the cargo-bottom area where my SD only has an empty plastic grill.
drzjoint
Jul 30, 2022 08:12 PM
hilltoppersx
ROAMING WITH FRIENDS
Jan 28, 2010 01:54 PM
dare u
Nov 11, 2009 06:46 PM
luxury1
Feb 6, 2009 07:34 PM
Rioja Red
Oct 28, 2007 09:25 PM
