Super Model With Bad Crack Habit Rehab Build-
Old 11-08-2015, 06:59 PM
ihscouts's Avatar
You can remove the solenoid pin or remove the entire solenoid....... Just remember to check your brake lights every once and awhile....... No wires involved. I leave my doors unlocked and keys in the ignition.....
I did the same for the transfer case shift interlock, removed the solenoid guts.
  #102
Old 11-08-2015, 07:21 PM
Detoured Discovey's Avatar
As much as I appreciate the reply......I'm not following you......any idea of the 2 wires out of 4?.......My key is always in, doors unlocked......but that's normal in these parts....hell my wallet & check book are usually in there as well....lol.
If you have the time.....interested in hearing more on the t-case as well!!!
  #103
Old 11-08-2015, 09:01 PM
ihscouts's Avatar
None, no can jumper it.
Yellow/red is fused 15A power into switch.
Green/purple (that's partially melted the wire connector) is hot out of the brake switch for the stop lamps to shine bright but the trans shift interlock is also using that green/purple wire through a relay to retract the shift interlock solenoids pin.
White/red is ABS.
White/gray is cruise control.
Sooooo....... what I'm saying is one snap ring removed pulls the guts out of the trans shift solenoid and you'll never have another stuck shifter ever again........ mechanical not electrical and everything stays put. Just check your stop lamps are working every now and then eh.
Remove the console - fun. Remove shifter *** and then the gear indicator and you have the shifter housing. It's on the passenger side of the housing so you have to do some more gyrations (I think I removed the whole housing) but it's really not all that hard......kinda. Once you get to the solenoid you remove a snap ring and out comes the pin and armature. Done.
While you have everything torn up you can get to the tcase solenoid - or at least see it......
The problem with the tcase shift interlock is it can hang locking the gear selector - not letting you change from high to low (unlocked or locked) or neutral even though the solenoid has power to retract the pin. It sticks. Again we remove the guts of the solenoid to evermore prevent us from breaking something within arms reach.
Sorry for the book but this little affair is going to refresh every four letter non-public word you know and then some. And you thought the panhard was fun......
Detoured Discovey (11-09-2015)
  #104
Old 11-09-2015, 04:19 AM
Actually I very much appreciate the time you took to write that and explain.
Thank you.
Sounds like a days worth of fun, I don't have a day just yet but will consider this when I do! I've taken the console out before, PIA...too bad about the dual use wire....of course it would have been too easy that way.
  #105
Old 11-09-2015, 07:26 AM
fishEH's Avatar
Check out page 2 of this thread. There's some good pics with what and where the solenoid is.
https://landroverforums.com/forum/di...k-45193/page2/
  #106
Old 11-09-2015, 09:47 AM
Thank you for that, that thread was helpful to me in more ways than one!
  #107
Old 11-09-2015, 03:23 PM
ihscouts's Avatar
I also removed the key interlock. Pretty much a standard 60's Jeep/Scout/Bronco with an alarm and electric windows.
  #108
Old 11-09-2015, 05:01 PM
I'll look into that! Thanks!
Not having a day to spare, I did have 14 minutes............
Soo.....
I had a 42 kicking around, I designed and had some parts laser cut a couple months ago.......but no time. I found 14 minutes today and finally installed.
I'll tell you what, it's cleaner than I thought it would be.....truly digging it!
I'll get a couple better pic's tomorrow as well as wire it up, but for now, winner-winner-chicken-dinner!!
  #109
Old 11-09-2015, 07:02 PM
ihscouts's Avatar
Way to spend 14 minutes, just blends in with the roof line. Stealth bar.
  #110
Old 11-11-2015, 06:22 AM
Stealth is pretty accurate I'd say, especially when I put the cover over it!
Better pic......
Quick Reply: Super Model With Bad Crack Habit Rehab Build-
