seat control work only when driver door open.
Old Jan 29, 2012 | 09:20 PM
discoman84's Avatar
7th Gear
Default seat control work only when driver door open.
hello to all my land rover fellow. So i have a weird situation here, need some advice. I have a 98 disco special edition, my driver seat control only work when driver door is open, when closed it play dead. Any suggestions are greatly appreciated.
Old Jan 29, 2012 | 09:57 PM
discoman84's Avatar
7th Gear
anybody???????????
Old Jan 29, 2012 | 10:00 PM
calculating
The relay that enables power to the seat is grounded by the door or the right seat relay. See drawing in second post
Last edited by Savannah Buzz; Jan 29, 2012 at 10:40 PM. Reason: can't see straight
Old Jan 29, 2012 | 10:22 PM
discoman84's Avatar
7th Gear
Thanks for the reply. So you saying my MFU could be short internally. Is there a way to test it? And one other thing when i open my driver's door i also heard the relay for the heated seat click, the yellow one right under driver seat. Can somebody send me a schematic for the seat motor control and the heated seat cant seem to find it.
Old Jan 29, 2012 | 10:39 PM
I've looked at this again. The driver seat attaches to the MFU for something like dome lights, etc. So that is not the issue. What is happening is that the right seat power relay is not energizing, or if it is the diode linking it to the left seat relay is open. Fuse 6 being bad in the under dash fuse box would also do this. So is the right seat working? Drawings attached, but you can have the whole set of RAVE shop and electrical manuals for free, just see link below.
File Type: pdf
Old Jan 30, 2012 | 10:24 AM
discoman84's Avatar
7th Gear
Got it figured out. went out this morning check my passenger seat sure enough it's not working. Check fuse 6 found blown fuse. Guess door switch is the back up ground for it in case this happened. Thanks for the help.
Old Jan 30, 2012 | 10:38 AM
No, IMHO the seat is enabled when driver door is opened so driver like me (shadow of fanny weighs 50 pounds) can manage to move seat and get in car to start it.
Old Jan 30, 2012 | 01:36 PM
Danny Lee 97 Disco's Avatar
So has your seat held up well under the overload condition Buzz?
Old Jan 30, 2012 | 02:11 PM
Chris-bob's Avatar
My seat will function with the vehicle off and door open, but as soon as you close the door, the seat will not move until the key is in the acc. position.
Old Jan 30, 2012 | 02:59 PM
Exactly - this allows the obnoxious maximus bad breath bib overalled redneck to move seat so he can get his immense body into the car driven in by the dwarf soccer mom who carries an 80 pound purse. Door does have to be open to supply that ground.
joshp01
Dec 5, 2021 07:50 PM
brandon4589
Feb 4, 2013 08:35 PM
1998DiscoverySE
Feb 8, 2012 02:41 PM
wheelgarage
Jun 27, 2011 01:19 AM
