Power Steering box, replacing seals
Old Sep 9, 2013 | 07:50 AM
tylor36's Avatar
Default Power Steering box, replacing seals
I finally got the floor and most of the drivers side fixed on my project, and now it seems alot of fluid is leaking out of the power steering box since I finally drove it a whopping 5.5 miles.
Anyway, does anyone have an experience replacing the seals with a seal kit for the steering box? I see reman ones are a couple hundred dollars, whereas I can find a seal kit for $56 on amazon. This is obviously not a daily driver so having it out for a while is not going to bother me.
So basically has anyone done this, and a difficulty level?
Old Sep 9, 2013 | 10:12 AM
jamescphillips's Avatar
Same question here - I've seen a post on this but it wasn't entirely clear how to do it.
Old Sep 9, 2013 | 10:26 AM
Mine is leaking also, and I was thinking about a new 2 quart reserve bottle....
Old Sep 9, 2013 | 10:29 AM
drowssap's Avatar
I'm not sure on a DI, but on a DII it appears you are better off buying a used box. It seems on a DII that very few people get them to seal correctly, and end up replacing the box. A DI could be a different story
Old Sep 9, 2013 | 10:57 AM
tylor36's Avatar
I guess I have to decide if I want to be a pioneer in this area. I am not sure if I will just go with a reman box. Mine looks to be the original (as in rusty as hell.)
It seems like it would be easy enough to get at and take out, but I can't tell if anything needs to be pressed in or out to get to anything.
This youtube video makes me feel a little better about doing it, does not look overly complicated if you ensure the seals set right and you torque everything.
DiscoBritney
Dec 19, 2011 06:24 PM
jpscinc
Sep 2, 2011 10:15 AM
losinov
Mar 21, 2011 08:57 PM
ljdiscovery
Feb 27, 2010 07:11 AM
jigray3
Sep 4, 2009 09:15 AM
