Rings & Oil Loss Issues
#21
Just because something is covered in oil doesn't necessarily mean that it is in need of replacing. Oil leak sources can be somewhere entirely different than where the oil/sludge buildup appears, as gravity, a moving vehicle, and vibrations can make oil/ fluids trickle/drip/creep to almost anywhere.
#22
That is total poppy **** if I ever heard it! If that's true then I'm going to get ovarian cancer because my Mum used Johnson's Baby Powder on my bum. If something is leaking it doesn't matter if it's in motion or sitting still, your going to see evidence where it shacks up at night.
colemtd (06-26-2016)
#23
#25
I've got a basket of ideas, no shortages on my side of the fence. I agree with Arch, one simple thing at a time until there's nothing simple left...... I believe you mentioned the spark plugs being very dark, huge clue if that's true. I checked your weather and remember how hot it can be. FishEh has used 20W50 weight motor oil with no complaints. That is a hot locale oil viscosity, you might want to try some.
colemtd (06-27-2016)
#26
ZDDP = 0.12 or 1200 ppm
HTHS = 4.9
I may be a bit biased as I used to represent ConocoPhillips in British Columbia, Canada
#27
#28
#29
Totally agree with ihscouts, and the best 20w50 to use that comes close to the ZDDP (zinc dialkyldithiophosphate) and HTHS (High Temperature High Shear) rating that we should have is Kendall GT-1 20w50.
HTHS = 4.9
HTHS = 4.9
