Rings & Oil Loss Issues
Old Jun 26, 2016 | 08:30 PM
  #21
colemtd's Avatar
Originally Posted by archaeology_student
Just because something is covered in oil doesn't necessarily mean that it is in need of replacing. Oil leak sources can be somewhere entirely different than where the oil/sludge buildup appears, as gravity, a moving vehicle, and vibrations can make oil/ fluids trickle/drip/creep to almost anywhere.
All very true! I was told that the reason I didn't see oil on the ground is because it's losing it when it's under pressure in motion and the wind is blowing it towards the back of the vehicle..
Old Jun 26, 2016 | 08:48 PM
  #22
ihscouts's Avatar
Originally Posted by colemtd
.......I was told that the reason I didn't see oil on the ground is because it's losing it when it's under pressure in motion and the wind is blowing it towards the back of the vehicle..
That is total poppy **** if I ever heard it! If that's true then I'm going to get ovarian cancer because my Mum used Johnson's Baby Powder on my bum. If something is leaking it doesn't matter if it's in motion or sitting still, your going to see evidence where it shacks up at night.
Old Jun 26, 2016 | 11:15 PM
  #23
colemtd's Avatar
Well then I guess I'm fresh out of ideas on where the oil is going.. It's not on the ground in the driveway..
Old Jun 27, 2016 | 03:10 AM
  #24
archaeology_student's Avatar
Just start with the simple things, and then work your way up to the more expensive things if it is not the simple things, and report your findings
Old Jun 27, 2016 | 11:21 AM
  #25
ihscouts's Avatar
I've got a basket of ideas, no shortages on my side of the fence. I agree with Arch, one simple thing at a time until there's nothing simple left...... I believe you mentioned the spark plugs being very dark, huge clue if that's true. I checked your weather and remember how hot it can be. FishEh has used 20W50 weight motor oil with no complaints. That is a hot locale oil viscosity, you might want to try some.
Old Jun 27, 2016 | 05:40 PM
  #26
Totally agree with ihscouts, and the best 20w50 to use that comes close to the ZDDP (zinc dialkyldithiophosphate) and HTHS (High Temperature High Shear) rating that we should have is Kendall GT-1 20w50.
ZDDP = 0.12 or 1200 ppm
HTHS = 4.9
I may be a bit biased as I used to represent ConocoPhillips in British Columbia, Canada
Old Jun 27, 2016 | 11:41 PM
  #27
colemtd's Avatar
Will do!
Old Jun 27, 2016 | 11:43 PM
  #28
colemtd's Avatar
Thanks so much, I will try it out!
Old Jun 27, 2016 | 11:45 PM
  #29
colemtd's Avatar
HTHS = 4.9
Thanks! Will keep you all posted...
seedsntrees
Feb 28, 2013 08:37 AM
mattrickman
Aug 22, 2012 05:21 PM
focusontheworld
Jan 26, 2011 03:24 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
ontheroadagain
Mar 27, 2008 08:10 PM
