2003 Disco II intermittent starting and front wiper issues
Old Jan 19, 2012 | 10:17 AM
Summitdog's Avatar
Default 2003 Disco II intermittent starting and front wiper issues
I have 2003 Disco that intermittently starts. I tried steering wheel trick, put car in neutral, replaced battery, cleaned terminals on both ends, and reset inertia switch.
When I turn key I get all function as normal starting, but when I go to crank it I get nothing no sound just dead. After a few tries of turning key back and forth and sometimes holding it down it will start.
I'm leaning towards start relay or new inertia switch?
I also have a problem with front wipers. It will take them awhile to get going and when they do they sometimes do go back down when I turn them off.
I'm thinking wiper motor or stalk switch?
Old Jan 19, 2012 | 11:11 AM
Usually the slow to pull in the cranking relay is related to the ignition switch.
Inertia switch can be bypassed with a jumper to check. If inertia switch is open fuel pump stops.
Starter relay controlled by the Body Control Unit, which interfaces with alarm to prevent starting.
Wiper problem is usually the stalk switch.
Page attached from RAVE tech manual for starter wiring diagram
File Type: pdf
shellshocked
LR2
Jul 2, 2013 09:55 PM
oljohnboy
Aug 3, 2012 09:40 PM
tsuami1
Feb 16, 2011 12:16 PM
baysiderover
Oct 6, 2006 06:58 PM
englishboyonice
Aug 18, 2005 07:23 PM
