Crankshaft front pulley
Old Dec 12, 2011 | 04:11 PM
928paul's Avatar
Default Crankshaft front pulley
this crankshaft front pulley with fan attached to is wobbling a lot, am I in big trouble? : (
Old Dec 12, 2011 | 04:29 PM
cipher982's Avatar
That's the pulley attached to the water pump.
You would have been if you never noticed this! Good job catching it before it got worse. I noticed mine was pretty bad too when I was investigating a coolant leak. Turns out it was coming right out through the front of the water pump bearing. Not a very big deal to fix. Just buy a new pump online $150-250 and replace the water pump, it'll be good as new.
Old Dec 12, 2011 | 04:38 PM
928paul's Avatar
Default where can i find a diagram for all the pulleys and belts?
where can i find a diagram for all the pulleys and belts? So I can put them back correctly. Thanks!
Old Dec 12, 2011 | 04:44 PM
cipher982's Avatar
Go ahead and download this manual: http://www.landroverresource.com/doc...hop_Manual.pdf
It is an electronic version of the service manual the mechanics use on these cars. Very helpful.
As far as the belt routing, I just google image searched 'Discovery II belt routing diagram' on my iPhone while doing the repair and it went fine. Aside from what the book says, make sure to scrape off all of the old gasket (which took me nearly 2 hours, compared to ~30 minutes to do everything else). And slap a PVC pipe over your ratchet when getting the belt on or off. It will give you enough leverage to easily turn the tensioning pulley with one hand so you can slide the belt on with the other.
EDIT: do you happen to have a 928?
Old Dec 12, 2011 | 06:53 PM
928paul's Avatar
thanks a lot! I sold my 928 long ago, I have a 944 and I modified it with air suspension!
Old Dec 12, 2011 | 09:05 PM
1. Pump will look like this inside. When it wobbles the small clearance makes it eat metal.
2. About an hour to do, plus time to remove fan clutch.
3. Be sure bolts go back in same holes, various lengths.
4. Belt route attached.
Attached Thumbnails Crankshaft front pulley-p1030593.jpg   Crankshaft front pulley-p1030596.jpg   Crankshaft front pulley-p1030595.jpg
File Type: pdf
Bago
Dec 18, 2014 06:01 AM
lo377
Nov 3, 2014 10:00 AM
ruining
Feb 12, 2013 12:32 AM
lipadj46
Nov 15, 2009 07:09 PM
Disco.Jay
Mar 4, 2006 09:08 PM
