idiots quest for more power?
I guess if I was going to do it, I would:
Start with a solid 4.0 block or a early Range Rover 4.6.
If using the 4.0 block add a 4.6 crank and rods
4.0 pistons
50229
ford injectors
polished and ported heads with a triple angle valve job
supercharger they made for the rover v8
Headers
free flow exhaust including cats
If I really wanted a fire breathing hot rod rover V8 though I'd probably call PT Schram
4.0 pistons
50229
ford injectors
Headers
Still, even the cheap job I had done made a difference of night and day.
4.0 pistons
50229
ford injectors
Headers
4.0 pistons
50229
ford injectors
Headers
having a bit of trouble finding the eaton kit that works best. i see the ones for the jag 4.0
talk of the m112 fitting in the valley and m90 more of a hassle.
also from rpi...
Warning against Supercharging the 4.0 or 4.6 Engine
have found some used optec units.
still researching.............
also from rpi...
Those with supercharges, will also discover this. On most supercharged engines, Especially those using the Eaton M90), poor fuel distribution and weak mixtures eventually cause detonation that will collapse the ring grooves on the rear cylinders and cause partial engine seizure, and eventual piston breakage"
RPi Engineering - V8 Engine and Component List
it would appear that the lack of carburetor and control of timing via dizzy would diminish the reward of a supercharger on these. outside of the Cameron concept rr sse, any other supercharged set ups that were offered? just on the jag, right?
looking like supercharger is more trouble that it would be worth unless I am missing something. so i feel like that avenue probably not the one i should take.
any mind changing evidence out there?
