If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
hi guys,
I have 99 disc ii with 99 k miles. it was running perfect up untill I had water pump failed, I was on the free way and it starts over heating pulled over found out heated hose busted replaced it and then found bad water pump. replace the water pump and flushed the cooling system twice it ran fine for aweek with out overheating. then it starts overheating I said might be air in the system followed the RAVE and purp the system put no way it stop over heating
replaced tstat, hoses. no water in the oil (drained the oil) no leaks even though I bypassed the heater coil with no success.
If its idling it doesn't overheat until I drive for a mile the temp climps in socends. and the reserve tank over flow with massive pressure. I tried everything I know and read with no success. any idea what is going on? I'm thinking I have combustion gases leaking into the coolant passages but the coolant it looks clean and doesn't smill like combustion gas. I dont want to do HG job and it is not the problem.
hi guys,
thanks
If it's not the head gasket it's got a leak at a sleeve and you need a short block with "top hat" liners. Your best bet is send your core to D & D Fabrications or Turner Engineering UK for exchange towards one of their remanufactured blocks. Don't mess with buying a used motor; you'll just get screwed. Believe me you can't trust anyone selling a used Land Rover motor; its for sell because its junk. If you don't get a block with "top hat" liners/flanged sleeves you are wasting your time and throwing your money away.
__________________
2001 SE7 Black/beige
MS screwed my block: bored cylinders off center.
Researching Toddco 5.0 HO: hoping they can accept my block as a core since they use bigger sleeves/pistons.
Miss it big time. Has been down a 14 months. (long sad story) keeps getting sadder. May give up on it soon if luck doesn't change.
@ 99k your due for head gaskets.
there is a kit you can buy that with check for exhaust gasses for about $50.00 at advances or autozone.
If you didnt over heat it too badly it a weekend and A $500.00 job if you can turn a wrench.
you should replace the thermostat, hoses, and concider the water pump while your there.
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
thanks guys for help I get fixed.
I've used the head gasket repair BLUE DEVIL and it worked very good. I been driving it for the past 8 days and it never over heated.
Please keep us posted, Blue Devil is considered a temporary fix by many. You may want to consider using the extra time it buys you to save up for the eventual head gasket job.
I would highly suggest you flush all the Blue Devil from your coolant system as well as remove and clean out your t/stat and install new green coolant or you will find yourself with one gummed up engine. Too many people have has long term side effects from using that product. That being said, I am a big promoter of White Shepherd products except for that one.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
