Overheating problem
Old Feb 3, 2012 | 04:01 PM
Ahmed's Avatar
Default Overheating problem
hi guys,
I have 99 disc ii with 99 k miles. it was running perfect up untill I had water pump failed, I was on the free way and it starts over heating pulled over found out heated hose busted replaced it and then found bad water pump. replace the water pump and flushed the cooling system twice it ran fine for aweek with out overheating. then it starts overheating I said might be air in the system followed the RAVE and purp the system put no way it stop over heating
replaced tstat, hoses. no water in the oil (drained the oil) no leaks even though I bypassed the heater coil with no success.
If its idling it doesn't overheat until I drive for a mile the temp climps in socends. and the reserve tank over flow with massive pressure. I tried everything I know and read with no success. any idea what is going on? I'm thinking I have combustion gases leaking into the coolant passages but the coolant it looks clean and doesn't smill like combustion gas. I dont want to do HG job and it is not the problem.
thanks
Old Feb 3, 2012 | 04:51 PM
2001SE7's Avatar
Originally Posted by Ahmed
hi guys,
thanks
If it's not the head gasket it's got a leak at a sleeve and you need a short block with "top hat" liners. Your best bet is send your core to D & D Fabrications or Turner Engineering UK for exchange towards one of their remanufactured blocks. Don't mess with buying a used motor; you'll just get screwed. Believe me you can't trust anyone selling a used Land Rover motor; its for sell because its junk. If you don't get a block with "top hat" liners/flanged sleeves you are wasting your time and throwing your money away.
Old Feb 3, 2012 | 05:24 PM
drowssap's Avatar
@ 99k your due for head gaskets.
there is a kit you can buy that with check for exhaust gasses for about $50.00 at advances or autozone.
If you didnt over heat it too badly it a weekend and A $500.00 job if you can turn a wrench.
you should replace the thermostat, hoses, and concider the water pump while your there.
Old Feb 16, 2012 | 09:19 PM
Ahmed's Avatar
thanks guys for help I get fixed.
I've used the head gasket repair BLUE DEVIL and it worked very good. I been driving it for the past 8 days and it never over heated.
Old Feb 16, 2012 | 10:01 PM
Please keep us posted, Blue Devil is considered a temporary fix by many. You may want to consider using the extra time it buys you to save up for the eventual head gasket job.
Old Feb 17, 2012 | 09:02 AM
I would highly suggest you flush all the Blue Devil from your coolant system as well as remove and clean out your t/stat and install new green coolant or you will find yourself with one gummed up engine. Too many people have has long term side effects from using that product. That being said, I am a big promoter of White Shepherd products except for that one.
2000 Disco 2 SD7
May 7, 2010 11:45 AM
substantialiscious
Jan 8, 2010 09:48 AM
josemex
Sep 15, 2009 09:47 PM
alanski
May 11, 2008 08:02 PM
DiscoBones
Aug 4, 2007 02:01 PM
