Sponsored by: CARiD
ac blower not working
Old Apr 6, 2011 | 02:55 AM
simpson lr3's Avatar
Question ac blower not working
I have a 2005 lr3 V8 SE, Tonight coming home from work i felt hot did not no why? look at the A/C IT was on but not blowing the lights work on the speed control for the A/C but it wont blow the rear A/C works fine but not the front help please i think it is the blower will find out in the morning
Old Jun 22, 2011 | 04:52 PM
jklefa2's Avatar
Any update on what happened? The exact same thing just happened to me.
Thanks!
Old Jun 23, 2011 | 07:54 PM
Rovin4life's Avatar
mostly the fan stops working cause the relay burns out, if that is good then make sure the fan has power and ground
Old Jul 7, 2011 | 05:42 PM
Ronnie's Avatar
4th Gear
The same thing, essentially, has happened to me:
1. no air coming from te front vents, neither hot nor cold
2. can feel the cold air just trying to come out
3. the a/c in the back works just fine
Where can I find this relay mentioned previously?
Cheers,
Ronnie
Old Jul 7, 2011 | 08:12 PM
Rovin4life's Avatar
underneath the passenger side near the fan. its a relay with two screws. its goes inside the hvac box.
Old Oct 6, 2011 | 12:05 PM
Ronnie's Avatar
4th Gear
Smile Thanks!
Thank you for the reply. I'm just now getting to this - school's been a bear and work is... work.
So I found blower motor relay on Amazon: http://amzn.to/qXH3rP I'm assuming this is the correct part. I've also had a look around in the passenger area, including under the dashboard, but I can't find an HVAC box. Mind you, I have no idea what I'm looking for! So when you say under the passenger side, you mean inside the car, under the dash. To the left? DO I have to pull the glove box out? I hate to be a PITA with so many questions, but I'm determined to make this repair myself. It sounds like it should be relatively simple and a good way for me to learn a little more about my vehicle. (I'm the type of guy that likes taking stuff apart and figuring them out, but that's usually confined to computers.)
Cheers!
Old Oct 6, 2011 | 12:11 PM
see below, from the RAVE; by the way, your own deluxe free copy is waiting for download as well. Covers it all. RAVE stands for Rovers A'int Very Economical. Would be on passenger side, may have to remove fascia trim panel under glove box. Find it in the RAVE under heating and ventilation
File Type: pdf
Old Oct 6, 2011 | 12:16 PM
Ronnie's Avatar
4th Gear
VERY COOL! Thank you, Savannah Buzz, I really appreciate it! I'll have a look at landroverresource.com in a bit, but that .pdf link seems to be hinkey.
Old Oct 6, 2011 | 12:25 PM
I reported that to Mike, not sure what is up with it, having problems with pdfs and pictures - they look great at my end, or if I go to edit mode, they just don't make the jump to hyperspace. Just started last night. Anyhoo, you'll want the whole RAVE, the D2 stuff is under pdf sub-file "L T"
File Type: pdf
File Type: pdf
Old Jun 4, 2012 | 06:14 AM
Niglaw's Avatar
3rd Gear
So I found blower motor relay on Amazon: Amazon.com: OES Genuine Blower Motor Relay for select Land Rover Discovery models: Automotive I'm assuming this is the correct part. I've also had a look around in the passenger area, including under the dashboard, but I can't find an HVAC box. Mind you, I have no idea what I'm looking for! So when you say under the passenger side, you mean inside the car, under the dash. To the left? DO I have to pull the glove box out? I hate to be a PITA with so many questions, but I'm determined to make this repair myself. It sounds like it should be relatively simple and a good way for me to learn a little more about my vehicle. (I'm the type of guy that likes taking stuff apart and figuring them out, but that's usually confined to computers.)
Cheers!
Hi Sirs,
I seem t be having the same problem.
Ronnie, how did you eventually resolve this problem?
Thanks
tsuyoi
Sep 22, 2020 10:37 AM
Stupinder
Jan 3, 2010 10:09 AM
imnappraiser
Aug 27, 2009 12:16 PM
MontanaPete
Nov 25, 2008 11:00 PM
eddyendo
Jun 1, 2008 04:41 PM
