Sponsored by: CARiD
Heater blower not working
Old Dec 31, 2009 | 06:00 AM
Stupinder's Avatar
Default Heater blower not working
Hi all,
noob here so be gentle
Last night the blower on the heater of the 1994 disco 200tdi stopped blowing and we have no heat. This morning i've replaced the relevant fuse to no avail.
I need to get this sorted by this evening as I'm feryying people about.
Any ideas?
I'm no mechanic by the way but follow simple instructions fairly well and i have access to basic tools 9- socket set, spanners etc.
Many thanks in advance.
Stup'
Old Dec 31, 2009 | 07:46 AM
Doubt that will happen.
Are all your blower speeds out, have you put a test probe to the blower motor wire, was the fuse burned out???
You will most likely find you need a new motor as long as all your blower speeds have failed.
Old Jan 1, 2010 | 08:40 AM
Rovin4life's Avatar
might be fan but most likely a issue with the switch assembly.
the ground for it is in the assembly.
if you dont have test lights and volt meters then take it to somebody with land rover experience.
you need to diagnose the problem before throwing parts at it.
Old Jan 2, 2010 | 01:28 PM
tedly797's Avatar
Known areas are the fan speed switch and the fan electrical connector. If you wiggle the speed switch, does it try to work? Look at the blower motor connector under the dah on the passenger side, is it burnt?
good luck!
Old Jan 2, 2010 | 01:55 PM
big will's Avatar
6th Gear
I had the same issue in my 02 disco. they took the heate panel off and there is a small plastic piece that burns out. the piece is super cheap online or they can rewire without it. Bottom line is the labor is an hour at best so don't let them take you to the cleaners on it.
Old Jan 3, 2010 | 05:05 AM
Stupinder's Avatar
Thanks guys. I have tried to respond before now but my posts aren't posting -no doubt me!
Old Jan 3, 2010 | 10:09 AM
If you still have problems posting let me know.
94svt50
Feb 28, 2022 10:24 AM
tsuyoi
Sep 22, 2020 10:37 AM
Rigndip
Feb 15, 2014 05:21 PM
yfdreserve
Jan 12, 2013 06:37 PM
preple
Oct 19, 2011 04:00 PM
