Flex or u joint
Old Apr 12, 2010 | 11:50 PM
tcrzoo's Avatar
Default Flex or u joint
96 discovery
with coustom body
cut 15" out of the frame
flex coupler is out
2"-3" lift will be installed or lift springs
should I buy a new flex or change to a u joint
Old Apr 13, 2010 | 07:55 AM
Having cut 15"s from the frame would increase the angle of the rear drive shaft, along with a lift, I would go with a double cardon shaft similar to the front shaft on a D2.
Old Apr 16, 2010 | 10:11 AM
antichrist's Avatar
15" shorter would probably need a propshaft with a DC on both ends depending on your flange alignments.
Spike555
Jun 2, 2009 11:19 PM
roverwoody
Oct 1, 2008 10:13 AM
Randy P
Oct 17, 2007 06:44 PM
tads
Oct 10, 2007 06:46 PM
fasterdammit
May 9, 2007 09:26 AM
