Flex Fuel
Old Oct 1, 2008 | 09:24 AM
roverwoody's Avatar
Default Flex Fuel
Has anyone did this converstion? Im thinking about it.
Old Oct 1, 2008 | 09:33 AM
Default RE: Flex Fuel
To run E-85?
Any car will run on E-85 without a conversion. I have ran a Camry, a Volvo turbo, a Ford vanand the LR on E-85.
Your MPG will drop so bad that it is not worth running it. Even at $1.00 less per gallon you will not save any money. There just is not enough energy in it to do any good.
It is a GREAT fuel injector cleaner, but thats all it is good for.
Seriously, you will lose 10-15% in fuel economy.
Old Oct 1, 2008 | 10:08 AM
There is no conversion to run E-85 there is however long term damage that can be caused by this.
Not a wise thingto do.
Stay with supreme and spare yourself any additional costs.
Old Oct 1, 2008 | 10:12 AM
Switzer's Avatar
From what I know (read, not very much) E85 is corrosive to fuel systems not designed to handle it. Stick to good old petrol and drive a little slower.
Cheers,
Pete
Old Oct 1, 2008 | 10:13 AM
Landzu's Avatar
You will need many new seals all on the fuel system from the fuel injectors
to the fuel tank,,with a 1995 Disco I you can set the timing your timing light
to compensate for the E85.
oysterhead
Dec 30, 2009 05:32 PM
Spike555
Jun 2, 2009 11:19 PM
Randy P
Oct 17, 2007 06:44 PM
tads
Oct 10, 2007 06:46 PM
fasterdammit
May 9, 2007 09:26 AM
