Correct way to FILL the Cooling syatem
Old Oct 25, 2011 | 08:51 AM
georgep's Avatar
Default Correct way to FILL the Cooling syatem
Replacing ALL the hoses, thermostat to fix what the dealer did not do. On ALL the English cars we have there is an AIR breather or on the XJS a 2nd radiator cap to let the air out of the system.
What is the trick to get this FULL?
The Rav is nice BUT the real world is better.
Old Oct 25, 2011 | 09:22 AM
Mrmerlin's Avatar
any chance you would like to give an idea of what car or truck your working on ?
Year, make, and model,
makes a diagnosis easier
Old Oct 25, 2011 | 11:39 AM
Mr. George is most likely wrestling with the Range Rover again, after a bout with a clamp under the coolant jug.
Old Oct 25, 2011 | 12:10 PM
georgep's Avatar
You got it, 2001 Range Rover. JUST got it back to the house from the land so will TRY and fix it one last time. This will leave the ONLY piece not changed out as the Water Pump.
Old Oct 25, 2011 | 08:29 PM
Rovin4life's Avatar
pull off the hose off the heater core and when fluid starts to come out after running it then put it back on and the air will bleed itself out. Or you could buy an air bleeder. hooks up with shop air and and puts a vacuum on the system. It can tell you their is a leak without putting coolant in it. And it bleeds the vehicle perfectly the first time
Externet
May 1, 2014 02:15 PM
sloppyjoe
Apr 1, 2010 06:02 PM
Disco Alan
Apr 21, 2009 06:22 PM
gsxrgessler
Jan 26, 2008 08:34 PM
MONTANACW
Feb 2, 2007 01:22 PM
