Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
steering wheel shaking
Old Nov 23, 2012 | 04:08 AM
paupau's Avatar
Smile steering wheel shaking
Hi,
I have a landrover defender 90 and since i have new tyres the steering wheel started to vibrate. Then i swapped the tyres with the ones a friend of mine was using on his landrover which are of the same brand and the same quality and the steering wheel did not vibrate. Could it be that the tyres are causing this problem? The steering box checked and it is ok. Not too shure about the steering dumber. The fact is that with other tyres the steering wheel worked fine.
Thank you
Paupau
Old Nov 23, 2012 | 05:39 AM
The damper is not the problem, although it can help mask it. Back to the tyre shoppe, they have balance off, or you threw a weight, or a tyre has a broken belt inside.
Old Nov 29, 2012 | 09:32 AM
paupau's Avatar
Thanks for you reply.
I am checking as well the arm drop. Hope fully i'll get this problem solved.
Madlands
Mar 1, 2015 08:15 PM
Externet
Sep 30, 2013 08:40 AM
maing74
Jun 27, 2011 08:34 AM
bangkuaidiscovery04
May 11, 2009 10:00 PM
LRDISCO
Dec 31, 2007 11:07 AM
